Full-Bridge LLC Converter with Synchronous Rectification
Full-bridge LLC resonant converter with synchronous rectification, optimized for Real-Time Simulations on the RT Box.
This component implements an isolated LLC resonant converter with a full bridge on the primary side and a half-bridge synchronous rectifier on the secondary side. To realize a full-bridge synchronous rectifier, use the CLLLC Converter component configured without secondary-side capacitance.
Certain parameters are associated with specific components. The corresponding component labels such as \(\mathrm{L}\), \(\mathrm{C}\), etc., are shown in Fig. 270.
- Primary inductance
A non-zero scalar for the resonant capacitance \(\mathrm{C}\) on the primary side, in farads \((\mathrm{F})\).
See Fig. 270 for the probe signal positions.
Fig. 270 Probe Signals for the Full-Bridge LLC Converter with Synchronous Rectification
