Matrix CLLLC Converter
CLLLC converter with 1/2/3/4-phase matrix converter frontend, optimized for Real-Time Simulations on the RT Box.
This help page applies to a set of components implementing isolated, resonant CLLLC converters with a 1-, 2-, 3-, or 4-phase matrix front-end. The topology can be configured as a dual active bridge (DAB) by omitting the resonant capacitors, or as an LLC converter by omitting the secondary-side inductor and capacitor.
Inductive currents must not be interrupted abruptly. Therefore, at all times, the combination of switch signals on the matrix front-end must provide a path for the inductive current of the primary winding. This can be achieved by ensuring that at least one high-side switch and one low-side switch are simultaneously ON in the direction of the current flow.
The voltage sources connected to the converter terminals must not be short-circuited. Therefore, combinations of switching signals that cause phase-to-phase short circuits or shoot-through conditions are not permitted. Additionally, DC voltages across diodes must not be negative, as DC voltage clamping through diodes is not permitted.
Certain parameters are associated with specific components. The corresponding component labels such as \(\mathrm{L}\), \(\mathrm{C}\), etc., are shown in Fig. 275.
- Primary inductance
A non-zero scalar specifying the primary-side inductance \(\mathrm{L_1}\), including the transformer leakage inductance and any external series-connected inductor, in henries \((\mathrm{H})\).
- Primary winding resistance
A scalar specifying the primary-side winding resistance \(\mathrm{R_{L1}}\), in ohms \((\Omega)\).
- Include primary capacitor
yes) or remove (no) a resonant capacitor at the primary side.- Primary resonant capacitance
If the Include primary capacitor option is set to
yes, this parameter requires a non-zero scalar for the capacitance \(\mathrm{C_1}\), in farads \((\mathrm{F})\).- Magnetizing inductance
- Include secondary inductance
yes) or remove (no) a series leakage inductance on the secondary side.- Secondary inductance
If the Include secondary inductance option is set to
yes, this parameter requires a non-zero scalar specifying the secondary-side series inductance \(\mathrm{L_2}\), including the transformer leakage inductance and any external inductors, in henries \((\mathrm{H})\).- Secondary winding resistance
yes, this parameter requires a scalar specifying the secondary-side winding resistance \(\mathrm{R_{L2}}\), in ohms \((\Omega)\).- Include secondary capacitor
yes) or remove (no) a resonant capacitor at the secondary side.- Secondary resonant capacitance
If the Include secondary capacitor option is set to
yes, this parameter requires a non-zero scalar for the capacitance \(\mathrm{C_2}\), in farads \((\mathrm{F})\).- Turns ratio
on, the block flags an error for combinations of gate signals that cause shoot-through or interruption of inductive currents.
See Fig. 275 for the probe signal positions.
A vector containing the currents through the inductors \(\mathrm{L_1}\) and \(\mathrm{L_2}\), in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
- Capacitor voltages
A vector containing the voltages across the capacitors \(\mathrm{C_1}\) and \(\mathrm{C_2}\), in volts \((\mathrm{V})\), defined positive at the sides marked with (+).
- Primary currents
A vector containing the currents at the primary-side converter terminals, in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
A vector for each phase containing the gate signals of the primary-side semiconductor switches.
Fig. 275 Probe Signals for the 3x1 Matrix CLLLC Converter
