Full-Bridge Inverter
Full-bridge voltage source inverter with filter inductance, optimized for Real-Time Simulations on the RT Box.
This component implements a full-bridge voltage source inverter including a filter inductor on the AC side.
Nanostep / SwitchedThe power semiconductors are modelled as ideal switches controlled by instantaneous logical gate signals. A switch is turned on when the corresponding gate signal is
true.In
Nanostep / Switchedconfiguration, C code generated from this component is suitable for real-time simulations on the RT Box, where it is executed on a Nanostep solver. In this case, connect the gate inputs to PWM Capture blocks from the RT Box component library.The Nanostep implementation requires the DC and AC sides to be galvanically isolated. Any electrical connection between the two sides outside the component would therefore not reflect the actual current and voltage situation and should be avoided.
Sub-cycle averageEach gate input is controlled by a floating-point number with values between \(0\) and \(1\), representing the relative on-time of the corresponding semiconductor over one simulation step, as described in Sub-cycle Averaging.
Sub-cycle averageconfiguration, C code generated from this component is suitable for real-time simulations on the RT Box, where it is executed on the CPU or FlexArray solver. In this case, connect the gate inputs to PWM Capture blocks from the RT Box component library.
This component has a Nanostep solver weight of \(1\), indicating that it occupies \(\frac{1}{3}\) of a Nanostep solver for Real-time Simulations on the RT Box.
Nanostep / SwitchedandSub-cycle averageabove.- Switch model (CPU code generation)
IGBTandMOSFETfor the symbol of the active semiconductor switches. This setting only affects the schematic representation and does not change the electrical behavior of the component.- Inductance
See Fig. 267 for the probe signal positions.
The current at the DC-link side converter terminals, in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
A vector containing the gate signals of the active semiconductor switches.
Fig. 267 Probes for the Full-Bridge Inverter
