Matrix Bidirectional Phase-Shifted Full-Bridge Converter
Bidirectional phase-shifted full-bridge converter with 3-phase matrix converter frontend and optional series capacitor, optimized for Real-Time Simulations on the RT Box.
../../_images/nanostep_matrix_bdpsfb.svg
This component implements a bidirectional phase-shifted full-bridge converter with a 3-phase matrix converter frontend and free-wheeling on the low voltage side. A series DC blocking capacitor to prevent transformer saturation is optional.
Inductive currents must not be interrupted abruptly. Therefore, at all times, the combination of switch signals on the matrix front-end must provide a path for the inductive current of the primary winding. This can be achieved by ensuring that at least one high-side switch and one low-side switch are simultaneously ON in the direction of the current flow.
The voltage sources connected to the converter terminals must not be short-circuited. Therefore, combinations of switching signals that cause phase-to-phase short circuits or shoot-through conditions are not permitted. Additionally, DC voltages across diodes must not be negative, as DC voltage clamping through diodes is not permitted.
Certain parameters are associated with specific components. The corresponding component labels such as \(\mathrm{L}\), \(\mathrm{C}\), etc., are shown in Fig. 274.
Primary inductance
Include primary capacitor
Allows you to include (yes) or remove (no) a DC blocking capacitor at the primary side, to prevent transformer saturation.
Primary capacitance
If the Include primary capacitor option is set to yes, this parameter requires a non-zero scalar for the capacitance \(\mathrm{C}\), in farads \((\mathrm{F})\).
Filter inductance
A non-zero scalar specifying the filter inductance \(\mathrm{L_f}\), in henries \((\mathrm{H})\).
Filter resistance
A scalar specifying the filter winding resistance \(\mathrm{R_{Lf}}\), in ohms \((\Omega)\).
When set to on, the block flags an error for combinations of gate signals that cause shoot-through or interruption of inductive currents.
See Fig. 274 for the probe signal positions.
Primary currents
A vector containing the currents at the primary-side converter terminals, in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
Filter current
The current through the inductor \(\mathrm{L_f}\), in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
Freewheeling current
The current through the snubber switch, in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
Primary gate signals
A vector for each phase containing the gate signals of the primary-side semiconductor switches.
Secondary gate signals
Snubber gate signal
The gate signal of the snubber semiconductor switch.
../../_images/nanostep_matrix_bdpsfb_probe_signals.svg
Fig. 274 Probe Signals for the 3x1 Matrix Bidirectional Phase-Shifted Full-Bridge Converter
