3-Phase Voltage Source Inverter
3-phase voltage source inverter with filter inductors, optimized for Real-Time Simulations on the RT Box.
../../_images/nanostep_vsi3ph.svg
This component implements a 3-phase voltage source inverter (VSI). It includes filter inductors on the AC side.
In Nanostep / Switched configuration, C code generated from this component is suitable for real-time simulations on the RT Box, where it is executed on a Nanostep solver. In this case, connect the gate inputs to PWM Capture blocks from the RT Box component library.
The Nanostep implementation requires the DC and AC sides to be galvanically isolated. Any electrical connection between the two sides outside the component would therefore not reflect the actual current and voltage situation and should be avoided.
Each gate input is controlled by a floating-point number with values between \(0\) and \(1\), representing the relative on-time of the corresponding semiconductor over one simulation step, as described in Sub-cycle Averaging.
Selects the component configuration. See the descriptions of Nanostep / Switched and Sub-cycle average above.
A non-zero scalar or 3-element vector specifying the inductances \(\mathrm{L}\), in henries (\(\mathrm{H}\)).
When set to on, the block flags an error for combinations of gate signals that cause shoot-through.
See Fig. 256 for the probe signal positions.
Inductor currents
A vector containing the currents through the inductors \(\mathrm{L}\), in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
DC link current
The current at the DC-link side converter terminals, in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
A vector for each phase containing the gate signals of the semiconductor switches.
../../_images/nanostep_vsi3ph_probe_signals.svg
Fig. 256 Probes for the 3-Phase Voltage Source Inverter
