Flyback Converter with Snubber
Flyback converter with leakage inductance and snubber diode, optimized for Real-Time Simulations on the RT Box.
../../_images/nanostep_flyback_snubber.svg
This component implements a flyback converter with a single output. In addition to the magnetization inductance, the transformer model contains leakage inductances on both the primary and secondary sides. To avoid excessive overvoltages when the switch is turned off, the primary side is equipped with a snubber diode. The diode can be connected to the positive input voltage rail via an RC snubber (resistor in parallel with a capacitor). It is assumed that the snubber capacitance is large enough that its voltage does not change significantly during one switching cycle.
Both sides of the converter have current source behavior. The primary side must be connected directly to a capacitor or a voltage source.
In Nanostep / Switched configuration, C code generated from this component is suitable for real-time simulations on the RT Box, where it is executed on a Nanostep solver. In this case, connect the gate inputs to PWM Capture blocks from the RT Box component library.
Each gate input is controlled by a floating-point number with values between \(0\) and \(1\), representing the relative on-time of the corresponding semiconductor over one simulation step, as described in Sub-cycle Averaging.
Certain parameters are associated with specific components. The corresponding component labels such as \(\mathrm{L}\), \(\mathrm{C}\), etc., are shown in Fig. 265.
Selects the component configuration. See the descriptions of Nanostep / Switched and Sub-cycle average above.
Primary inductance
A non-zero scalar specifying the primary-side inductance \(\mathrm{L_1}\), including the transformer leakage inductance and any external series-connected inductor, in henries \((\mathrm{H})\).
Primary winding resistance
A scalar specifying the primary-side winding resistance \(\mathrm{R_{L1}}\), in ohms \((\Omega)\).
Secondary inductance
A non-zero scalar specifying the secondary-side series inductance \(\mathrm{L_2}\), including the transformer leakage inductance and any external inductors, in henries \((\mathrm{H})\).
Secondary winding resistance
A scalar specifying the secondary-side winding resistance \(\mathrm{R_{L2}}\), in ohms \((\Omega)\).
See Fig. 265 for the probe signal positions.
Input current
Output current
Switch current
The current flowing in the active semiconductor switch, in amperes \((\mathrm{A})\), defined positive in the direction of the arrow.
Gate signal
../../_images/nanostep_flyback_snubber_probe_signals.svg
Fig. 265 Probes for the Flyback Converter with Snubber
